2.4 Smoking HELP !! - Maintenance and Repair Forum
2.4 Smoking HELP !!
Wednesday, February 16, 2005 3:11 AM
Let me give you the short story.
About a week ago, I did an oil change on my 2000 Z24 with the 2.4 Twin Cam engine. Castrol Syntec Blend 5W30, and ~1 Qt Lucas Oil stabilizer, to what [I thought was about a total of] 4.5 Qt. I've been using a little Lucas for the past many oil changes, no problem, and I use it religiously in my '89 Z24. Anyway, I head to work. 22 Mile drive. Towards the end of the drive, I ran around 5000 RPM for around 30-40 seconds (Going up fairly steep hill, for a 4 lane highway, accelerating). I pull off the offramp, smell a little something weird. Pull into the parking lot, and smoke's coming up out of the hood. Doesn't smell good. I check my oil later and I'm at the "add 1 qt line". Don't have any oil, so I drive it real light on the way home. I pull into the driveway, smoke is minimal (but remember I drove it lightly). I get home, and I add 1qt of Castrol Syntec Full synthetic.
Tuesday, I go out, drain the oil and change the filter, thinking maybe I got a bad filter or something, which has never happened before. While underneath the car, I notice that oil seems to be all over, and seems to be originating from the rear, lower-middle portion of the motor (nowhere near the filter), up too far in a cranny to really pinpoint, I just know that there is more oil on the lower rear of the motor and tranny pan than I am used to seeing. I wiped everything clean, so I could tell if it gets covered again. Anyway, I reuse the oil since it is still clean, (refilling it with a straining funnel) and fill it to the top of the Full range. I drive it lightly to work and back (44 more miles round trip), still smell the smoke, but only actually see minimal smoke. I checked the oil level and it seems to be in operating range, but it's so dark I can't even tell, since the oil is still so clean.
After all that's happened, the car still starts easy, and seems to run fine. Only thing I notice is that the motor seems a little warmer when I come to a stop than I think it should be, though I haven't really paid much attention to it before. I am not overheating, according to my temp gauge.
I will be pulling it up on ramps on Wednesday to see if I am still leaking. I really hope not. Has anything like this happened to anyone with a 2.4 Twin cam? This motor has 54000 miles on it, and the only modding I have done thus far is MSD Ignition, and a short ram warm air intake.
Somebody please tell me you know what I should do?!! Thanks in advance 1000x!~!!! I care much for the car, and don't want it to DIE!
--==pghcavman==--
Re: 2.4 Smoking HELP !!
Wednesday, February 16, 2005 3:23 AM
Oh yeah, forgot to mention that I checked my coolant, to see if somehow I blew a head gasket. Coolant's 100% clean. If it's a gasket, it's external leakage only.
BTW, I haven't taken apart a DOHC motor yet. I've taken heads off of, and put back together both a 2.2 I4 OHV and 2.8 V6, but no OHC motors yet.
What could have happened here?
--==pghcavman==--
Wednesday, February 16, 2005 11:14 AM
Most likely its just an oil seal somewhere. Probably the crankshaft seal. If you have a hayns manual or another repair manual look in there to see how to change the engine seals. If your not comfortable with that just take it to a mechanic. Unfortunately it is expensive to have a mechanic do it where as the part itself is pretty cheap.
Thursday, February 17, 2005 2:56 AM
Well, I just got home from work about an hour ago, and no signs of smoke. I will be checking my fluid levels tomorrow and see what I see.
--==pghcavman==--
Sunday, February 20, 2005 4:14 PM
It's been about a week. No more sign of smoke, and running fine.
--==pghcavman==--
Sunday, February 20, 2005 7:01 PM
that lucas @!#$ sucks. dont use it.
running at 5 k for like 40 secs probably just made your engine extremely hot, which had something to do with metal expaning and oil going where it wasnt. idk if that made sense.
-Borsty
Sunday, February 20, 2005 11:57 PM
aint nothing wrong with lucas, its a proven product and it works!
_______________________
** Flat Broke Racing Inc.**
