I have a ld9 with a m45 with a 2.5 snout pulley and a 7 inch crank pulley (stock alt pulley)looking for a part number or a belt size that will work with this setup?
thx....
It's as simple as running a piece of string the way the belt would be routed and measuring the length needed.
2001 Olds Alero (LD9)
636 whp / 543 ft-lb
@turboalero
Most people with that setup run a stock length belt.
how would a stock size belt work?
he means stock gm supercharger belt that came with the kit, not the stock non supercharged belt.
RIP silver car. You will be missed.
ok so I can use a gatorback 4100729 with a 2.5 snout pulley and a 7 inch crank pulley
the bigger belt I have is the one running a 2.9 snout and a stock pulley
