Cavalier Thompson wrote:Tinkles(KGM) wrote:That's better. A 8" wide wheel with 35mm offset is already getting close to not fitting on our cars.
so how close will 18x8.5 +40 be??
Just by going off the clearance i have seen with 8" width and 35mm offset, i'd have to say that they will touch. The wheel is wider and the higher the offset, the farther in the wheel will sit. You might get by with 10mm spacers, but you will need extended wheel studs.
You guys should use
THIS website.
Works even better if you have an idea of strut to wheel/tire clearance and fender to wheel/tire clearance of your current set up.
________________________________________.
Still not low enough for a signature.
