hmm thats interesting...I will have to try that out.....its just bizzarre that ever light on the cluster is on
Goodbye Bobby, May God grant you the peace you never found in life.
“Here's my counter-offer to your counter-offer: go f**k yourself.”
—Al Swearengen
Every light = bulb test, does it not??
Maybe the white wire from the ignition switch is fux0red. That could cause that.
...j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
hmmm the only wires I touched were in the engine bay...from the plug to the pcm....never anything inside
—Al Swearengen
Besides pass lock being the problem.....did you listen when you turn the key to hear if the fuel pump is even turning on???
of course........I am not an idiot........everything that could have been check was checked.....its some bizarre electrical problem
—Al Swearengen
