Running at 16volts, ecu electronics etc... - Audio & Electronics Forum
Monday, April 04, 2011 8:23 PM
Anyone successfully ran 16 volts on their ecu, headlights, etc? I've read of people running it on their silverado's, tahoe's, suburbans and such but can't find anyone doing it with a cavalier or sunfire.
Re: Running at 16volts, ecu electronics etc...
Tuesday, April 05, 2011 5:14 AM
ECUs don't like it. What's the need for a 16 volt system?
Tuesday, April 05, 2011 7:07 AM
You can use an MLA module to boost your voltage a bit higher, around 15v or so.
Most running 16v on a system have it on a separate electrical circuit than the PCM and factory bits.
Tuesday, April 05, 2011 7:51 AM
16 volt batteries need your alternator to run at 18+ volts. Not healthy for the rest of the electrical.
Saturday, April 09, 2011 7:40 PM
I swear I saw some batteries that ran at 16 volts and had a separate terminal to run your 12v stuff off of..
Sunday, April 10, 2011 6:27 AM
also Powermaster makes step down boxes.
about the MLA... they are VERY easy to make for our cars. I made one that can be turned on or off, and when its on i have a knob inside the car to raise the voltage up to 21v. not that i ever went over 16v
Wednesday, April 27, 2011 7:45 PM
Forgot I even posted this, I do believe I will be running a stepdown and "mla" module. Did you just use an adjustable resistor to make the knob?
