Indiglows?? - Audio & Electronics Forum
Indiglows??
Sunday, February 20, 2005 8:51 PM
Here we go!!
I bought a new set of indiglows (reverse glow) so I'm replacing my current ones but when I installed the old ones I used the power from the fog lights and it works great the only thing is when I turn the fog lights off the indiglows go off I know somebody has a how to some where. I used the search but no luck. I need to know which wire should I tap into so the new gauges don't get the same side effect that the old ones have?
Your help is greatly appreciated.
ECOTEC POWER
ECOTECRDR
<IMG SRC="http://memimage.cardomain.com/member_images/6/web/642000-642999/642348_12.jpg" HEIGHT=140 WIDTH=240>
and you say it couldn't be done.....
Re: Indiglows??
Monday, February 21, 2005 6:33 AM
On my 97 cav, I used the yellow wire and the black (or brown, can't remember) wire from the dimmer switch. Use a voltmeter to check, but I think that's correct.
Re: Indiglows??
Monday, February 21, 2005 8:01 AM
Thanks Daryl
ECOTEC POWER
ECOTECRDR
