whickh way to fire it..sub that is.. - Audio & Electronics Forum
Saturday, February 19, 2005 12:49 PM
i know this subject has been done and talked about many time s but please bear with me.no flamming needed...I have a 15"jonah lomu in a 3.6 cuft box tuned to about 35htz. The box has the port on the same side as the sub but the question lies with which way i should fire it. I have been told that since there is little room on either side of my box and none above that i should fire it forward or take out my 6x9's and make a large hole for my trunk to breathe. But if i face it forward i avoid lomost all these problems...right or wrong? Also does anoyone know if its going to make a difference or not? the reason i ask is cause its not like this box comes out easy..usually takes a couple hrs..lol...thanks for the help..phil
Re: whickh way to fire it..sub that is..
Saturday, February 19, 2005 2:48 PM
It depends on if you're gonna be keeping the rear seat up all the time, or down when really using the system.
Brakes? I don't need no stinking brakes....I have air bags
http://members.cardomain.com/charlzo_2000
Saturday, February 19, 2005 3:56 PM
i would amost always leave the seat down unless i was carting around some firends...but 9 times out of ten it would be down...phil
Sunday, February 20, 2005 1:16 PM
just set it up and move it around, everybodies system is different. and it might sound better to you in one position then another.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Monday, February 21, 2005 6:03 PM
i know with my 2 10's in a sealed box personally sounds better facing the rear and when i have them facing fowards it sound like #$%^ especially with the seat up.... and its not nearly as loud....
!!!jbody Customs!!! yo hit me up if you need anything!
streetfire2006
