backup battery ( HOW TO) - Audio & Electronics Forum
Friday, February 25, 2005 1:43 AM
how would i go about installing a backup battery to my alarm.... i know its not as simple as just running a wire from a battery in your trunk to the alarm...because it would die...it needs charged from an alternator or something...
Re: backup battery ( HOW TO)
Friday, February 25, 2005 4:20 AM
depending on what kind of alarm you have manufacturers will have a backup alarm for it, contact the manufacturer of your alarm and see if its available.
Friday, February 25, 2005 8:22 AM
theres a piece you hook up in line from your alternator to split off power to both batterys while not letting yoru second battery draw from you first and vice versa. not sure what its called . i'm sure wysiwyg knows, he has a battery in his trunk.
Friday, February 25, 2005 12:51 PM
your thinking of an isolater heretic wich is used if your running two batteries. joe smith is talking about a battery backup for his alarm in the case of a theif cutting his power wire, the alarm will continue to go off.
