My left low beam doesn't go on.... (I aready changed the bulb socket, the bulb itself and the left headlamp fuse).... it still doesn't go on.. all new parts and tested on the right side and they all work.... can't get the light to go on on the left side (drivers) ... is there a relay that i can check or something else to verify.. if so, where is it and how does it look like??? please, can anybody give me other solutions???
Thanks!!!
The left side has a relay for the DRL's. When you put your can into gear, does your right headlight blink a few times? If it doesnt then the Relay is dead. I dont remember where it is off the top of my head, hopefully someone with better knowlegde of it will help you. And this should be in the maintance forums.
Fact 1:
“Facts are meaningless. You could use facts to prove anything that’s even remotely
true.
