Making my own harness for 2000 - Audio & Electronics Forum
Wednesday, March 02, 2005 10:41 AM
For awhile now i've been wanting to put a deck into my 2000 sunfire, but as everybody knows, the good people at GM want it to be a pain in the a$$. Since i haven't been able to find a reasonably affordable harness up here in ontario (one store even quoted me $200 canadian!!!) i've decided to make my own. I know all the wire colours/codes and i have a mechanic to help me out. I can get a gm harness cut out of a junker for about $35 canadian and a 24-pin harness for about $20. Just wondering if there is anything I should know or if there is any advice anyone can give?
Thanks
Re: Making my own harness for 2000
Wednesday, March 02, 2005 11:01 AM
look in the faq
Wednesday, March 02, 2005 11:35 AM
yeah, if your talking about the relocation harness, you dont even need it. Just get a gm 2003 harness, or a gm 2002 harness for a satur, and figure out what the speaker wires are. The purpals, and the greens are different. i recommend the gm 2003 harness, and then you need to go to the fuse panel for the 12v switch. Its located at the wiper fuse.
Forget the relocation harness.
Wednesday, March 02, 2005 12:56 PM
I asked this question like a month ago, its not really that possible because the wiring for the T-harness is sort of complex and if you want the chime to ring from the drivers side speaker you need to wire in 2 relays. And its not really worth it because it'll probably end up costing you more to make it.
If you want to keep the chimes , you have 3 options:
1)Metra/Scosche T-harness , which requires an additional speaker for the chimes, relocates the stock deck to the trunk.
2)Best kits BHA2004T (I got this one) it has 2 relays and the chime noise comes from the drivers side front speaker. It also relocates the deck to the back
3)Metra GMVRC-01 chime module, this plugs into the stock plug and provides a chime noise from a speaker that is built into the module. The stock deck is not needed with this option.
OTHERWISE IF YOU DON'T CARE ABOUT CHIMES:
Get the tracker, prizm harness Metra GM2003 (I believe)
Wednesday, March 02, 2005 2:18 PM
i've got a spare t-harness if you actually want it. i'll beat that 200 dollar price as well, lmfao
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, March 02, 2005 5:08 PM
Canadian Tire sells the 00+ Gm harness now. It's like $15...
..j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Wednesday, March 02, 2005 11:56 PM
70-2003 is the metra part # for the harness, most any stereo shop should have it.
1st 1st gen on air.....
Thursday, March 03, 2005 5:52 AM
Ok guys thanks!
