Different Firing Rate - Audio & Electronics Forum
Wednesday, March 02, 2005 6:01 PM
I have two 10" subs in a sealed box, running on the same channel however the drivers side sub is firing at a slower rate then the opposite.
All the settings are the same for both subs
How would I go about solving this problem?
Thanks
Re: Different Firing Rate
Wednesday, March 02, 2005 6:48 PM
maybe you have positive and negative mixed up on one sub?
Wednesday, March 02, 2005 7:07 PM
^^if that is the case, one sub will be playing at a considerabley lower volume then the other.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, March 02, 2005 7:31 PM
Thanks Guys I'll check that in the morning
