Connecting Amp to Subwoofer box - Audio & Electronics Forum
Tuesday, March 01, 2005 7:11 AM
I heard that if you bolt down the amp to the subwoofer box, your bass would damage your amp.
Is that true?
<img src="http://memimage.cardomain.net/member_images/8/web/788000-788999/788881_2.jpg">
If you do the speed limit, get the fu<K outta my way.
Re: Connecting Amp to Subwoofer box
Tuesday, March 01, 2005 8:08 AM
2 years for me, and no problems here
Tuesday, March 01, 2005 8:24 AM
I personally like it on the back seat. Dunno if its any better then on the sub box, I guess its all personal preference?
Brian D.
Tuesday, March 01, 2005 10:30 AM
Mine's been bolted to the box for as long as I've owned it. Unless you just get a really shoddy amp, it shouldn't be a problem.
______________________________________
Hell hath no fury like a pissed off balloon animal.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
Tuesday, March 01, 2005 4:29 PM
no one has proved it, some have had amps die and they say it was do to the amp being on the box. but reality would show you that the car driving down the road and hitting potholes and going up curbs will do more vibrational damage then a subwoofer box that shouldnt be vibrating at all if its built half way right.
Tuesday, March 01, 2005 5:47 PM
sndsgood wrote:a subwoofer box that shouldnt be vibrating at all if its built half way right.
that's sometimes the problem...kid's get lazy and build their boxes outta 5/8" particle board or something else that resonates and flexes like crazy.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Tuesday, March 01, 2005 5:53 PM
then they learn their lesson, don't they. 3/4" mdf is the key
"Sup, G?"
"Aren't you white?"
Tuesday, March 01, 2005 6:32 PM
Bloodspiller wrote:then they learn their lesson,
we can only hope. That's the reason why i rarely would tell someone to mount the amp on their box. just in case. But if you know what your doing then it's a different story.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Wednesday, March 02, 2005 7:51 AM
I touched my box with the subs on and your right, there is very little vibration. Almost none.
Thanks for your help.
Wednesday, March 02, 2005 8:01 AM
I hardly take out my box so moving it wouldn't matter to me
http://www.cardomain.com/member_pages/view_page.pl?page_id=788881
Wednesday, March 02, 2005 8:28 AM
the biggest downfall i see to an amp mounted to the sub box is most people also dont bolt the sub box down so it makes a nice neat package for a theif.
Wednesday, March 02, 2005 1:30 PM
i used 5/8 mdf and well im having no problems in fact ive moved both my amps up to the box and purchased a third amp in order to power better subs, but yah wutever, i used 3/4 and 5/8 smae dimensions and well no probsyet goign hard since september
Wednesday, March 02, 2005 8:05 PM
depending on where its mounted on the box, box flex MAY damage it, if the box is the proper thickness and has good bracing their will be no damage, just make sure its mounted over atleast three braces(front or rear edge, and center brace) preferably over four or more, mines mounted on a piece of board bolted into my passenger seat with spacers to keep it from rubbing stays cool, stays dry, lets me fiddle with gain/crossover if i need to while stopped at a light
wicked
