keyless entry - Audio & Electronics Forum
keyless entry
Friday, March 04, 2005 9:10 AM
sup guys does anyone have instructions on how to reprogram a 98 z24 keyless entry remote
Re: keyless entry
Friday, March 04, 2005 1:23 PM
Yup!
Before you do this, roll down the driver's side window and close the door. That way you can still get in if you get locked out somehow
Pull back the carpet on the driver's side of the trunk. There's an empty connector, which comes off the received (black box bolted to the metal rod on the inside of the wheel well). Put a jumper between the terminals of the connector (paper clip, short wire, whatever.. it's not a lot of power there)... the door locks will lock, unlock and (I think) the horn will honk. Then you hold down the lock and unlock buttons together on the remote(s) you want to reprogram. Hold for about 5-10 seconds, and the car will lock, unlock the doors and honk again. Then remove the jumper when you're done.
Only works on 95-99 J-cars. 2000+ need to go to a GM dealer, because the Tech2 is needed.
...j
<a href="http://www.lenkorules.com/"><img src="http://s93165229.onlinehome.us/images/zm/sig/LRDCsig3.jpg"></a>
Re: keyless entry
Friday, March 04, 2005 6:28 PM
effin showoff.......
<img src="http://img78.photobucket.com/albums/v290/americonium/Heavy_weight.jpg ">
