Can you run speaker wires next to your power wire? - Audio & Electronics Forum
Monday, March 07, 2005 5:44 AM
Just curious. I will be running some Q form kick panel pods and the speaker wires will go underneath the threshold trim, probably right next to my power wire. Now, I know that you aren't supposed to run the RCA's next to your power wire because of noise interference. Will the same thing happen if I run the speaker wires right next to the power wire? Thanks in advance for any replies to this thread.
Trying to become the most modded out N/A 2nd gen sunbird 4 cylinder on the org with a..... screw that, I'm going turbo!!!
2.Slow OHC I4
Ported cylinder head, intake and exhaust
Relocated IAT with a custom WAI with a 6x9 K&N conical filter
All this, and I still can't go fast.............yet!!
Re: Can you run speaker wires next to your power w
Monday, March 07, 2005 7:04 AM
your fine, the speaker wire wont pick up the whine.
<img src="http://www.j-body.org/registry/blingblingfire/personal_pic.jpg">
Monday, March 07, 2005 7:27 AM
Even signal cables in car dont really matter too much. Remeber, everything is grounded to the body of the car anyway.
"all your bass are belong to us"
Monday, March 07, 2005 10:17 AM
Unless you're pushing a lot of wattage (a couple thousand at least) you won't get any induction noise on your lines.
______________________________________
Hell hath no fury like a pissed off balloon animal.
"Sup, G?"
"Aren't you white?"
"Only on the outside, craka."
Monday, March 07, 2005 11:58 AM
thats not ture, I'm only running 85x2 and i have it
Monday, March 07, 2005 1:53 PM
have you pinned down your noise cavi?
90% of the time noise in the system is caused by improper grounds.
