hey man.. what's up...
i've had the 251D for about a week and let me tell you.. it was great and hit hard with my mtx 300 watts rms MZS...
if i were you.. pay a bit more and get the 251D... I promise you, you will thank me.
Carlo
what impedence your woofer is would make a huge difference. if it is a SVC 4 ohm then get the 202. Which is a two channel bridgeable. if it is a 2 ohm load then get the 251 d
it is a 15w0, right now, but dont plan on having much longer than spring......
4 ohm
Any body else????
the store is running seriously low on stock...
only 2 of one , and 3 of another left in stock....
Class D. Only because you don't get the full potential out of the other amp. However, if you decide to get the class A now, and then the class D later, the class A can be used for speakers, where as the class D won't do you any good.
<img src="http://img78.photobucket.com/albums/v290/americonium/Heavy_weight.jpg ">
I already have my speakers running off a 5:0:4 Phoenix gold Octane, so, i dont think i will be needing this to run any speakers.....
I am thinking of going the 251D............
unless someone can change my mind...
I just got back from Futureshop, where i looked at both of these amps, the only thing i hated about these is the size of these!
these are truly tiny amps!
anyone else put off by this?
