Quick Questions about stock offset and pattern - Wheel and Tire Forum
Wednesday, December 23, 2009 6:11 PM
hey everyone
I was wondering if someone could tell me really quick what the range of offset is for a cavalier that hasn't been modified at all? What is the offset of the stock rims on a 2004 cavalier? I don't know what rims will fit and which ones won't.... the bolt pattern is 5x100mm, correct?
any help is appreciated. thanks!
And now you are reading my signature...great
My 2004 Sunburst Orange Sedan - http://www.j-body.org/forums/read.php?f=47&i=54063&t=54063
input is highly appreciated!
Re: Quick Questions about stock offset and pattern
Wednesday, December 23, 2009 11:25 PM
pattern = 5x100
offset range = 35mm - 45mm
WiGM-Tuners member.
Thursday, December 24, 2009 11:33 AM
alright, thanks. Does the rim's width play into the offset range as well?
Thursday, December 24, 2009 11:41 AM
no. there will be a number after the size of the rim. example: 17x7. or 18x8. the wider the rim, u want alittle lower offset. so it doesn't rub on your suspension.
i have 18x8's w/ a 42mm offset. if i went w/ a 45mm offset. i probably would rub.
WiGM-Tuners member.
Thursday, December 24, 2009 11:49 AM
okay, that makes sense. So what would be the limit of rim diameter without doing anything else? I think that I'm only going to get like a 17 or 18", but im just curious where the point is that the rim is too big?
Friday, December 25, 2009 10:49 PM
8" wide is probably the limit as far as not modifing anything.
WiGM-Tuners member.
