Center consol/hand brake question - Interior Forum
Friday, May 28, 2010 9:45 PM
I am going to replace my 95 cavy center consol with a 2000 center consol. I like the 2 cup holder up front. Also noticed, I really like the leather boot on the hand brake.
How do I get that leather boot in my 95? Do i need to take out the entire hand brake assembly and replace my existing one?
Re: Center consol/hand brake question
Saturday, May 29, 2010 4:39 AM
The boot is attached to the inside of the console. The end around the e brake handle just slips over the handle and slides off, then the bottom of the boot has metal ring sewn inside that clips into the console, and can be swapped between consoles.
Saturday, May 29, 2010 7:19 AM
alright cool. So I dont need to swap the handle, the boot will fit on the 95 also?
Thanks
Saturday, May 29, 2010 12:35 PM
Just swap consoles...the 2k one is far better.
M62, 42's, ZZP 3", ZZP S3 H/E
214whp 190wtq
Saturday, May 29, 2010 3:27 PM
you also need the metal bracket from the 2000 and up consoles.
Saturday, May 29, 2010 5:32 PM
what metal bracket? underneath the console?
Saturday, May 29, 2010 7:42 PM
^^ Yes, once it's out, you'll see what he's talking about.
214whp 190wtq
Saturday, May 29, 2010 10:34 PM
ok cool. thanks
and just too clarify, for adding a leather boot. You remove the boot from under the base and slide it over top. and to put it on the 95 e brake you put it on inside-out, then twist-tie or staple it to the handle, and then pul then rest back down over the twist-tie/staple and its all good?
Sunday, May 30, 2010 8:14 AM
i dont even think its that hard, but you got the right idea
www.driftnamiperformance.com
Monday, May 31, 2010 9:09 PM
do I need the metal bracket? I was jsut at the junk yard and got my consol but didnt grab the metal plate underneath. If I take that plate I'll need to take the shifter and handbreak assembly with it. im confused...
Thursday, June 03, 2010 10:26 PM
its not going to bolt down .. already tried that.
Friday, June 04, 2010 12:39 AM
ill make it fit some how. No way am i swapping out the handbreak and shifter as well...
Friday, June 04, 2010 2:51 AM
u shouldent need to. the bracket bolts down on the same studs as the shifter.
Friday, June 04, 2010 11:57 PM
well, I'll give it a shot soon here without using the metal bracket from the 2000 and up consoles.
I'll let you guys know how it goes..
Monday, February 14, 2011 9:28 PM
Lots have tried, it will be off.
Tuesday, February 15, 2011 2:42 PM
....I did mine....had to remove the stock front bracket...made a cheapo from 3/4 x 1/8 or 1/4 inch aluminum stick from lowes and worked perfect...your never gonna see it....all you have to do is loosen the back nuts and take off the 2 on the front, pull up on the assembly and wiggle the stock one out...easy as hell to do...car was a '96 sunfire..console was a '00 plus......if you use the power supply on the newer console then you will have to cut and splice your stock one...easy as hell too and easy to put back stock
2003 Cavalier
Stock 2.2 Liter, 5 speed
" Leave the rice to Uncle Ben's and the wings to KFC..
Go clean or go home. "
