Kickpannels! - Audio & Electronics Forum
Im looking for somewhere to get some custom kickpannels done for my car, anyone know anyplace, or anyone that can do it, or have a pair that will fit a 6.5 mid? Car is a 97 cav. Thanks anyone for the help!
where are you from?
try q-logic. they are pretty nice.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Upstate NY, right outside albany
can't help ya here. I'd have to use your car to make you a custom set. Either learn to do it yourself, pay some shop, or buy q-logic's.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Yeah, i know not to go there. Im not a noob, i just dont really like working with fiberglass, and wanted to see if someone knew where i could get some. Looks like im just gonna have to do it myself. The only problem is the smell makes me REALLY sick, maybe i will have to get the bubblegum scented resin from SP
wear a respirator..you should do that anyways.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Yeah, i always did, i just have very bad reactions to things. Last week i was cleaning around alot of dust and ended up having to be in bed for like 16 hours before i started to feel better. It sucks to be so sensitive to things
I'll take a picture of my kickpanel project tonite. I put a 3 way component set (6 1/2, 4, and 2 inch tweeter) in my door panels of my sunfire. In the rear where the arm rest areas are, they're getting another set of 3 ways.
Beat it like it owes you money
Ok so here we go. This was my first fiberglass project and it turned out really well. Only thing I have to do is add the tweeter.
wow, that looks great. what brand are those? never seen 3 way components
^those aren't kickpanels, those are door pods, but they look nice none the less, lol
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
Thank yee
Well, they are panels, and they'll prolly get kicked! They're Audiobahn ABC6003 - 6 1/2, 4, and a 2 inch tweeter. I don't have the tweeter in yet.
Lanman31337 wrote:Ok so here we go. This was my first fiberglass project and it turned out really well. Only thing I have to do is add the tweeter.
Did you cut the fabric behind that pod or no? I am building the same thing, except the 6.5" is in that pod, and the rest is in kicks (3way). If you did cut the fabric/plasticy stuff behind that pod, how did you get the pod to stick to the door?
Thanks.
Vice President - NEJBody
2007 Cobalt SS
2001 Sunfire (retired)
I have the q logic ones. I am not a big fan of them. They seriously lack midbass. and they do not fit a 6.5 without modification like a mofo.
This is what I did. I dremeled that triangle section out of the door, did my fiberglass, then put it back in with liquid nail. Off the back side you can see the liquid nail, and off the front it doesn't look too bad. As for mid-bass, they sound gooooooood.
sweet. someone told me that liquid nails would not bond the plastic to the glass. Have you thought about glassing to the door around the seams to make a seamless one piece bottom part?
2007 Cobalt SS
I had no problems with liquid nail. It worked great. I thought of making it one piece, but it looks fine as the 2 piece. Maybe later I'll use some filler and combine them.
I have the q-logic kick panels in mine. The plastic was kinda flemsy, so I through some fiberglass on the back of it, made a big difference. Here is a pic...
the q-logics are ok...you do have to glass the backs though, which isn't hard.
As for them lacking midbass, that's most likely because they are open on the backs, and not sealed at all. I tried a lot of stuff with mine trying to get more bass out of them but nothing worked short of sealing them up.
A 3 way setup using them would be ideal, 6.5" in the door, then the tweeter and 4" in the kick.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
6.5's fit fine in the q-logics..
I thought they'd lack midbass also, when test fitting them, they had noticable gaps in a few spots..
How hard is it to glass the backs of the kicks? I'd have to form the back of the kicks to the carpet area right?
Maybe make an enclosure for the doors also? I'm using Infinity Reference 6.5" comps(kicks) and 6.5" mids for the doors, all amped.
"If life throws you a curve, pop the clutch and drift it!"
yea, i fit 6.5's in mine fine by mounting them from the back.
and by glassing the backs, i mean reinforcing them, not sealing them up. You COULD easily make a mold of your carpet area and then glass that mold to your kick, but you would have to texture paint them after your done. (or smooth them out...whatever)
for the doors, no need to make an enclosure just for the speaker, that's what the door is for. Deaden it like crazy though because cavy doors are like tin cans. You will want to seal up the inner skin the best you can also. the more sealed up it is, the better response you'll get.
SOUNDSTREAM
DB LINK
DB DRIVE
PANASONIC
GARMIN
ROSEN
SCOSCHE
XE DESIGNS
SOUNDGATE
PAC
LITEGLOW
either star quester or brisk, do you have a picture of the drivers side kick panel in relation the clutch? i wanna see how close it is...this is what i have to work with
2007 Cobalt SS
Nah man, sorry I don't. Mine is an auto, but I'm almost 100% sure that you will have problems with the clutch. Nore sure tho....
